flash file
Old Apr 13, 2006 | 07:51 PM
indy500's Avatar
Default flash file
i'm running 12 psi , procharger ,injectors 24lb, racetonix fuel pump, ported heads , cam 224/228 581 , 114 .
i need ls1 edit flash file . is there any one with smiller setup ?
Old Apr 14, 2006 | 04:37 PM
indy500's Avatar
come on guys ...no one here ...
Old Apr 14, 2006 | 04:40 PM
horist's Avatar
I believe edit can at least read .bin files (repository) ... I would never reccommend blindly flashing w/someone elses tune, but may be something to look at
also 1 oddity... you meant 42lb injectors right? 24lb wouldn't be too good stock, much less boosted heh
Old Apr 14, 2006 | 05:08 PM
indy500's Avatar
yes right its a 42lb injetors ...
i just need to read file and compare it with mine ...
you know im livn' in middel east and its to hard to tune the car here . here in my city there is just on dyno and they are not that much in FI cars .
