LC-1 Error #8
The unit is brand new so the sensor shouldn't be broken. All my connections and grounds are solid. I've done the heater calibration and free air cal. Not sure where to go from here. Ideas? It's wired to run with HP Tuners if that matters. Thanks for any help!
Red: 12V switched
Blue: Chassis Ground
White: EIO Ground (Grounded to engine block)
Green: EIO Ground
Black: EIO Ground (run through led and push button switch)
Yellow: Unused and taped up
Brown: EIO Input
I followed SoundEngineer's instructions. I'll have to look for JoeCar's wiring. Thanks!
