Predator..how does plug look?
Old Apr 16, 2006 | 08:21 PM
rotwiler's Avatar
Default Predator..how does plug look?
I have had a Predator tuner since 03, never a problem, then last week I changed some settings, everything was fine. Plugged in the Predator a few hours later to check codes on a friends car and it said key needs to be on, cannot connect. So, I thought it could be just his car, then today my car threw a check engine light and when I plugged in the Predator, the same thing happens to me. It comes up with key must be on etc.... even when it is.. So I am thinking maybe one of prongs in the plug may have fell out or isn't making a connection, I looked and there are 3 prongs in the Predators plug. One looks like it is sticking out slightly more than the other 2. Before I try to fix it, I want to make sure there are only 3 prongs on the plug. So, if anyone could answer this, is appreciated.
Old Apr 16, 2006 | 08:31 PM
rotwiler's Avatar
Nevermind...is 3, I took the plug apart and a a wire needs to be attached.
