Crank position sensor.
Old Apr 17, 2006 | 09:46 AM
Ryan'sSS's Avatar
Default Crank position sensor.
My crank position sensor is out again only 2 weeks after it had been replaced.
What could be causing this? Since I have had a H/C install it has went out twice, each time after about 500 miles of driving.
Old Apr 17, 2006 | 12:54 PM
Gordy M's Avatar
Are you performing the CASE (crank angle sensor error) Learn procedure when you put in the new sensor. As I was told the PCM is not recognizing the sensor and the angle of the deviation from the PCM firmware.
Old Apr 17, 2006 | 01:27 PM
Ryan'sSS's Avatar
No, did not do that. How do I perform that without any tuning software?
The car ran strong for 2 weeks after replacing the sensor. Is that normal?
