crank sensor
Old Apr 17, 2006 | 09:29 PM
anthonyz281999's Avatar
Default crank sensor
so when i pulled my motor out i ripped the connection for the crank sensor....in other words..the conneceter is still in the block and the wires got ripped out of the harness...can i just spilce these wires where they came out of and be on my way ? or do i need to buy a new sernsor ?
Old Apr 17, 2006 | 09:55 PM
Duffster's Avatar
It would depend on how badly damaged the wires are. If you can soldier them back and heat-shrink them for protection and then add a sleeve to protect them from vibration and such, you might be able to get away with the repair. . .
FYI, "Sensor,CR/SHF POSN - AC-Delco PN #213-354 / 12560228
http://www.paceparts.com/index.asp?P...D&ProdID=43790
about 45 bucks. . .
Duff
Old Apr 18, 2006 | 09:05 PM
MEFISTUFF's Avatar
if you just need the connector and pins, give me a call@574 267 5554
and i'll send you one. steve
