mail order tune or street tune??
imho it goes street tune w/wideband, dyno tune, mail order tune , mail order should really only be used for minor changes, but not for performance (unless you can find someone to work with you where you send them logs and they make changes)
I've never heard of the individual you named above though...
Good Luck.
Bill
Making the all out max power sits backseat to making sure that the car drives great. IMHO
I've done two cars with TR 230/224's in the past 2 weeks. (98 Formula and 00 Z) In both the driveablity turned out really well on the first guess and needed to only be slightly touched up. If both cars had Lterms less than 6 AVG across the board on my first guess what does that tell you? hopefully that it is possible to see trends in how this stuff works
My point is your first guess if seasoned should get the car driving really well. You may find that the particular car responds better with different timing on the dyno but you will definately not be able to tell on the street. Use of a track (if the car is consistant) or dyno is imperitive
My case on that is this... I helped some guys last wednesday tune in a car that they tuned in on the street. They where pretty confident the timing they chose was making the most power.. After seeing what the car liked on the dyno we found 18rwhp. AFR before and after was spot on. (they did a really great job on fueling before we even touched it)
If I was a fresh guy that just bought HPtuners or EFIlive I would strongly consider buying a base file from someone seasoned if the car had a cam in it just to get me going in the right direction. Especially on idle and what you can do w/ part throttle timing. The learning curve is a bit steep on this stuff. Its by no means rocket science but its not entirely intuitive either.
im confused sorry...are you saying that you think a mail order tune would be ok or to get a different tune thanks
