New Hptuner/Eio
Old Apr 20, 2006 | 05:32 PM
SLP4CamaroSS's Avatar
Default New Hptuner/Eio
how do u connect a lm1 to the new hptuner/eio?
Old Apr 20, 2006 | 05:42 PM
Magnus's Avatar
LS1TECH Sponsor
These links may help:
http://www.hptuners.com/help/vcm_sca...connecting.htm
http://www.hptuners.com/help/vcm_sca...nstall_lc1.htm
Old Apr 20, 2006 | 06:08 PM
horist's Avatar
^^^that pretty much gives you all you need
To summarize:
1. Analog out goes into input #1
2. Analog Ground goes into ground input on cable
3. Program LM1 for desired range (I have mine setup for 10-16 AFR, 0-5 volts, w/a custom wideband PID)
4. Add PID for wideband to your scanner table
and you're set... LM1 is really easy to hookup... just two wires to HPT basically
Old Apr 20, 2006 | 06:28 PM
custome widebad pid?
Old Apr 20, 2006 | 06:36 PM
bmfcamaro's Avatar
no. they have the lm1 preconfigured
Old Apr 20, 2006 | 06:39 PM
on my lm1 i see a gold white and red wire
and i heard u got to ground it to your car and then to the eio or wahtever
Old Apr 20, 2006 | 07:12 PM
horist's Avatar
the instructions say which one is analog 1 and 2 and which is ground, just need the ground plugged to the EIO , and analog 1 plugged into the cable ... w/LM1 it's just two wires
The main ground for the LM1 is the cig lighter
The reason I created a custom userdefined PID for my wideband is i am using non pre-defined ranges (10-16 at 0-5v instead of 10-20 at 0-5 volt)
