inovative tuning probs.
Also, how can you log with the software that came with the inovative LC-1? how can it know your rpms? other than the a/f it tells you nothing.
I dont have the enhanced version of hp tuner, and how can you do this easily without it? or can you? if you cant why would they sell it without?
the car is 99 formula, ported heads, 224/.581 cam , headers x-pipe, yank SS 3800 stall, 4.10s, slicks, and it runs really good.
Im just confused how the A/F could be so off, or is it the damn wideband giving faulty readings? we calibrated it, and the light is on steady meaning ready for use. no trouble codes.
thanks.
The software has the LC-1 option also. I can log AFR and rpm and map, on the histogram or the chart. You can also use the VE AFR% error histogram and copy & paste the table to your ve table if your sd tuning. If your tuning your maf, use the maf error histogram.
This is the best way to tune. I would upgrade your interface to the MPVI PRO version. It is $199.00 and you get the VCM Suite 2.16 and there is a 2.1.8 update as well. The 1.XX version doesn't have the maf error histogram.
Russ Kemp
