cutout and a/f ratios
Old Apr 23, 2006 | 03:39 PM
Hennytime's Avatar
Default cutout and a/f ratios
when they put the sniffler in an open cutout to read the a/f ratios does it skew the readings at all?
Old Apr 23, 2006 | 03:59 PM
txhorns281's Avatar
low rpm readings might seem a little leaner, WOT should be fine, supposing you have no other leaks upstream, pretty accurate on the dyno
Old Apr 23, 2006 | 07:22 PM
Hennytime's Avatar
bump.
Old Apr 25, 2006 | 08:37 PM
txhorns281's Avatar
was that not satisfactory enough for you?
Old Apr 26, 2006 | 12:45 AM
SmokingWS6's Avatar
My wideband in the collector and the dyno's in my cutout were less than .2 off.
