Converter lock up mind of its own
Old Apr 27, 2006 | 12:46 AM
white1's Avatar
12 Second Truck Club
Default Converter lock up mind of its own
Im working on my trans tuning right now, and when I get my TCC lock up set how I want it, it works for a while, then may, or may not work. It will lock up when forced through the HPT scanner, and sometimes it will work by itself, but others it wont. Where should I start looking? Is it something mechanical, or in the tune??
Old Apr 27, 2006 | 01:41 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
If you are getting a PO300 code for random misfires that will cause the random lock up problem. I'd check the TDC and see if you have any in the history even if you are not getting the SES light.
