Tuning for Nitrous
Old Apr 27, 2006 | 01:07 AM
white1's Avatar
12 Second Truck Club
Default Tuning for Nitrous
I dont spray my truck, but Im gonna hit it with a 100 or 125 shot next weekend, and a 125, or 150 two weekends after that. Is there anything that I need to do besides bump the timing down?? Also, how much timing should I remove? I think Im running about 36* right now
Old Apr 27, 2006 | 04:12 AM
LoWeLL216's Avatar
I'm not familiar with the "normal" timing for your truck, but alot of guys will drop it 1-2*/50hp. Not tuning related per se, but I'd change to a colder plug and run the proper safety devices as well if you're not already. (wot switch, window switch, fpss, etc).
Old Apr 27, 2006 | 11:30 AM
MrDude_1's Avatar
make sure you wont hit the rev limiter.. its a fuel cut limiter, and cutting fuel on nitrous is a no-no.
i wouldnt pull out timing unless i was spraying a larger shot.... assuming you're running the proper nitrous plugs and all, just do it like a bolt on kit.... no timing changes.
if your engine is modified, check your WOT AFR with a wideband before you spray.. you dont want to be lean before you start spraying..
Old Apr 28, 2006 | 11:02 PM
Reject's Avatar
i'm in the same boat about the tuning for nitrous, wanting to know what all to tune for a nitrous shot (150)
Old Apr 28, 2006 | 11:07 PM
brad8266's Avatar
You can run the 150 shot without pulling any timing. here is how i tuned for nitrous.
I tuned it NA to a AFR of 13.0 @WOT, easy, kept stock timimg tables too. Then just threw on 62 n2o jet and a 33 fuel jet. My AFR on the juice is low 12's at mid rpm's to low 11's at the high rpm's. Plenty safe.
There is no need to pull timing on a shot of that size. Just be sure to have enough fuel and dont activiate the nitrous till at least 2800 rpm's
Old Feb 19, 2007 | 12:00 AM
yobabiesdaddy2001's Avatar
Brad,
what up grades was the 150 shot with?
