High Idle & Lean Codes
Old Apr 29, 2006 | 02:26 PM
LSWONTA's Avatar
Default High Idle & Lean Codes
Just finished installing my Stage 3 Ported heads and weiand intake.Already had an F11 Cam.My problem is when i start it up i get about a 3000 rpm idle and setting codes for MAF wich i already switched out with a new one and Fuel Trim lean codes.Already checked for vacum leaks around the MAP sensor and intake using starter fluid and cant seem to find 1.How off will my current tune I had for the F11 cam be know that added heads?It sets the MAF code pretty quick then the fuel trim codes follow.I can clear the codes and it will idle gr8 at 900 rpm but after a few it will either die or idle up high again.Any help appreciated.
