ABS Documentation?
Old Apr 29, 2006 | 08:52 PM
2002_Z28_Six_Speed's Avatar
Default ABS Documentation?
Anyone have any documentation on which wires are which on the 30-pin ABS 4 channel module under the hood?
I have found pin-outs for the wheel sensors due to a LS1-Tech member. Since then I have eliminated that as my problem.
I would really like to know what pin is the serial communication from the ABS module to the star pack connector and where it should end up inside of the car!!!!
Anyone have a factory service manual PLEASE!?
Old Apr 30, 2006 | 03:48 PM
Spenser309's Avatar
http://www.ls7power.com/diagrams/sys...g.diagrams.pdf
scroll down to the one you need.
Old Apr 30, 2006 | 09:19 PM
Got it.
Now the wheel sensors are good and the connection from the ABS to the star pack is good. I had to run a new wire.
The Service vehicle light has now gone out.
ABS INOP, BRAKE are both still on. ASR OFF light has now come on.
ABS doesn't work..
Any ideas of what to check next???
Old May 4, 2006 | 07:50 PM
No one on this site ever seems to know anything about ABS.
Old Aug 19, 2007 | 11:33 PM
sic2001's Avatar
sameproblem here, did you ever find out what it was? Heres what I got with the same symptoms c0550 ecu malfunction,c0896 voltage range,u1301 communication any help would be great. I heard the left head has a ground on it that comes loose but I cant see it to check it
