Need some help with electrical...
Old May 1, 2006 | 02:30 PM
RedlineBrian's Avatar
Default Need some help with electrical...
Not sure if this is the right section for this but here it goes...
Ok guys this happend to me a few months back but i just swapped out a new fuse and the problem disappeared...for a while.
What keeps happening is my number 7 fuse (PWR ACCY) keeps blowing. Every time i park the car i have to put a new fuse in. I know i am using the proper fuse. I must have went through 5 or 6 fuses yesterday. Then comes the night time and i noticed i had no tail lamps. I check that fuse (fuse number 5 TAIL LPS) and it too is blown. I replaced that one and so far no problems with that one. What do you guys think is going on?
There is only one odd thing that i notice. When i replace the #7 fuse i notice a blue spark when putting it in and you can also here the spark crackle. Is that normal? It didn't happen when i put in the #5 fuse.
Do i have a short somewhere that would be causing these problems? That seems like a logical explanation to me, but where? Where should i start to look?
Any help is appreciated from anyone. Please i need it because this problem is a real pain in the ***.
-Brian
Old May 1, 2006 | 03:37 PM
white2001s10's Avatar
Yes you have a short. Start with standard short troubleshooting techniques.
You seem to have already narrowed down the circuit. You will have to trace wires on that circuit. A common technique is to unplug or remove loads from that circuit until the problem disappears.
A test light comes in handy for tracing shorts.
Old May 1, 2006 | 04:27 PM
Thanks.
Old Apr 18, 2009 | 07:58 AM
WS6FirebirdTA00's Avatar
Digging up an old thread, but what was the solution? Same exact issue here.
Old Feb 23, 2012 | 04:02 PM
stupercharged's Avatar
Same here both fuses keep blowing in my
Girlfriends 2000 ss I cnt figure it out.
Old Feb 23, 2012 | 05:23 PM
ggino85's Avatar
ws6firebirdta, My car started doing that when i had the wrong kind (from a different vehicle) of cigarette lighter plugged into it. kids or dumb friends somtimes put pennies in the cigarette lighter port/plug. just some ideas.......
