Definition of WOT
Old May 12, 2006 | 11:18 AM
pHEnomIC's Avatar
Default Definition of WOT
I keep hearing that many things get disabled at Wide on Throttle. I was just wondering, what exactly do ls1's consider wot, Is it when the pedal is completely floored, or does it also include when the pedal is like 3/4. What is the range on this?
Old May 12, 2006 | 12:05 PM
Ric's Avatar
Ric
Something I've wondered as well. Does the PCM "fade" into the WOT tuning parameters, or does it switch at a certain throttle position, what's the low-down, gurus???
I do know AC and EGR turn off at WOT.
Old May 12, 2006 | 01:47 PM
digitalsolo's Avatar
Wide OPEN Throttle.
IIRC, what is considered WOT can actually be adjusted in the tables on the PCM. I believe stock is something like 89 or 92%.
Old May 12, 2006 | 01:59 PM
Phoenix 5.7's Avatar
it depends on what the setting is. i have my A/C WOT setting at i think 85%. it goes by % programmed. if u wanted, WOT could be set at 5%, although that wouldn't make sense
Old May 12, 2006 | 11:14 PM
brad8266's Avatar
WOT generally means pedal to the floor, but the computer goes into power enrichment mode (PE) when the throttle is opend a certain percent which is specified in the vehicles PCM.
