Trying to Get IAT to PCM when MAf Disabled
LABELS Selection
Parameters Value
{C2901} MAF High Frequency Fail 1 1.000000 Hz
{C2903} MAF High Frequency Fail Limit 1.000000 failures
{C2904} MAF Low Frequency Fail 1 1300.000000 Hz
{C2906} MAF Low Frequency Fail Limit 6.000000 failures
{C2907} MAF Test Min Engine Speed 400.000000 RPM
{C2908} MAF Test Min Run Time 2.000000 Seconds
{C2909} MAF Test Min Batt Voltage 8.000000 Volts
{C2910} MAF Test Max TPS 95.000000 %
According to the EFILive tutorial if the MAF has a five pin plug you must make provisions to get the IAT signal into the PCM.
The tutorial tells you to check the forums on how to do this.
http://68.178.219.18/tutorials/AutoV...20Tutorial.pdf - page 10
