Help!! Which Wideband??
Old May 22, 2006 | 11:54 PM
Purrvert's Avatar
PLX M350, plug and play.
Old May 23, 2006 | 07:42 AM
MrDude_1's Avatar
Originally Posted by bluehawk2
What is the major probs with the lc-1. I have seen several posts on probs with it. They say it is a bad batch. The calibrations on the lc-1 looks like a pain. Still don't know which one to get. Afraid I might be stepping into a lot of probs with the LC-1.
most of the major problems stem from people:
  • not reading the directions correctly
  • shorting out the outputs to power or ground
  • grounding problems from people (once again) not wiring it correctly
  • there was one bad batch, and the inital run had some firmware glitches that have since been fixed
if you buy it new from someone like DynoTune that sells enough to stock the new, current ones, you shouldnt have any issues.
