Locking torque convertor up at WOT in 3 gear
Old May 25, 2006 | 06:48 PM
1fastxz's Avatar
Default Locking torque convertor up at WOT in 3 gear
Any one here has the convertor locking up when the trans shift to 3 in the 1/4?
I have done it befor in my old car(99Z) and it went faster, just wanted to know if anyone has tuned the a4 to lock up in 3 at the track?
05 LS2 GTO
Old May 25, 2006 | 08:12 PM
SSpdDmon's Avatar
Unless you have an aftermarket stall, you might want to becareful about doing this. It doesn't exactly have the same clamping power as a normal clutch.
Old May 25, 2006 | 08:31 PM
usd2sing's Avatar
correctamundo!!! not recommended with a stocker...
Old May 25, 2006 | 10:36 PM
1fastxz's Avatar
have a fuddle HPseries going in very soon
Old May 26, 2006 | 12:34 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I would like to see some real results on this as well.
I will be providing some results soon with a triple disc lock up converter through my Rossler 4L60E. I think the 408 should be able to handle the load to maintain the momentum on the top end. Is it worth ET/MPH and how is the big question. I'll start a new thread when I get the back to back results. I'm still lining out the new set up.
