First time EFILive for readiness test
Old May 27, 2006 | 11:34 PM
ls1_bc's Avatar
Default First time EFILive for readiness test
This is my first time using EFILive. I have to take my car in for an Air-Care test next week. I have !AIR !EGR. So I disabled these codes
EGR
P0400 EGR Flow Malfunction
P0401 EGR Performance
P0402 EGR Excess Flow Detected
P0404 EGR Pintle Position Error
P0405 EGR POS sensor low volt
P1404 EGR Pintle Closed Position Performance
P1406 EGR Pintle Position Error
P1409 EGR Vacuum Leak
AIR
P0410 AIR System
P0412 AIR Solenoid relay control circuit
P0418 AIR Pump Relay Control Circuit
P1415 AIR System Bank 1
P1416 AIR System Bank 2 codes
in both Engine DTC Processing Enablers and Engine DTC MIL Enablers this seems to have taken care of my SES light. I also noticed that there is a further reference to EGR in Engine Calibration\EGR\Parameters EGM System Enable\Disable should I switch the value to disable?
I do have to pass a vehicle readiness test before they put it on their rolling road and measure emissions. Will this pass readiness or are there any other adjustments I should make?
Thanks
Old May 28, 2006 | 06:29 AM
TAQuickness's Avatar
try running the readiness test in the scan tool. If it's not all green, you will need to revise your codes
