Some help for Camshaft Tuning
Old May 29, 2006 | 12:09 PM
misho911's Avatar
Default Some help for Camshaft Tuning
Hi Everbody...
I have canshaft from Compcams is :
1- Headers LT
2- Exhaust with Magnaflow Mufflers
3- Airflow Intake dual
4- Camshaft :
Style: Hydraulic roller tappet
RPM Range: 2,800-7,200 RPM
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 240
Duration at 050 inch Lift: 238 int./240 exh.
Advertised Intake Duration: 287
Advertised Exhaust Duration: 289
Advertised Duration: 287 int./289 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.605 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.609 in.
Valve Lift with Factory Rocker Arm Ratio: 0.605 int./0.609 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
could someone tell me which tables in the hp tuners i use it and values ????
