Closed Loop A/F
Old May 30, 2006 | 08:43 PM
White_LightningZ's Avatar
Default Closed Loop A/F
I know the pcm tries to keep it at 14.7. It does this to reduce emissions not that it is the best ratio for fuel economy or performance (open loop is much more important to performance I'll be running 13:1 there).
My question is (without running widebands) is there a way to have the car run leaner than 14.7 in closed loop (like tricking the computer/ tuning etc.)??
Old May 30, 2006 | 08:58 PM
JimMueller's Avatar
There seems to be some success in raising the O2 switchpoints. I haven't read anything else to alter AFR in closed loop.
Old May 30, 2006 | 09:21 PM
fast98's Avatar
actually you lower the switchpoints and it does work, i run about 16:1 at cruise
Old May 30, 2006 | 09:33 PM
JimMueller's Avatar
Whoops, got it backwards. Thanks for clarifying
Old May 31, 2006 | 06:54 AM
speedracer5532's Avatar
can you give some guidance on how much you lowered them?
Old May 31, 2006 | 07:17 AM
JimMueller's Avatar
Try this thread. It's for HP Tuners, but hopefully it's similiar in EFILive (if you're using that instead) ...
http://www.hptuners.com/forum/showthread.php?t=4929
Old May 31, 2006 | 11:51 AM
fast98's Avatar
no problem ..............my switchpoints are a little different then in that thread. i find that a value of 526 is to high mine doesnt go above 457. maybe when i get home later on my laptop i will post up some of my stuff
