different ltfts
Old Jun 1, 2006 | 02:00 PM
Tiger2o69's Avatar
Default different ltfts
Just installed heads and cam and my ltft's are a bit off from each other... My bank 1 is around -1 to -2 and my ltft bank 2 is around -4 to -7... Could this be an o2 sensor or an exhaust leak?
thanks
Ill try and get some logs and more info... thanks
Old Jun 1, 2006 | 02:24 PM
SSpdDmon's Avatar
Try and look at more than just the LTFT's. Pick a couple VE cells in a couple different fuel trim cells. What's the difference between the (AVG_LTFT+AVG_STFT) for bank 1 and bank 2 in those cells? What I'm getting at is, the LTFT for bank 1 might be -3%. But the STFT's might be averaging -1% effectively giving your fueling a -4% correction. If the other bank has a -6% LTFT and avg STFT's are +1%, then you have a -5% correction....or a difference of 1%. 1% is not that much, but it looks like more when you see -3% and -6%.
