Timing tables for N2O
Old Jun 2, 2006 | 07:47 AM
Big Geek's Avatar
Default Timing tables for N2O
I am using HP Tuners and the current N2O tune is WAY to rich so I was thinking that since I am running a wet system and it uses it's own fuel supply why not take the N/A tune and replace the High Octane timing tables in it with the ones from the N2O tune and save it as a seperate tune for the N2O. Does this sound feasable or am I out in left field? I do NOT need the the current fuel % that the N2O tune is running (They are KILLING my plugs.) and from what I am seeing the VE tables seem to be much more suited to my combo in the N/A tune. Any suggestions? Any and all help is greatly appreciated and thank you in advance. Take care.
Jim C.
PS- I have a Racetonix pump so fuel supply isn't an issue.
Old Jun 2, 2006 | 05:25 PM
WS6 GreeN's Avatar
So are you wanting to dial in a 13:1 air/fuel ratio off the spray, and use the fuel jet to make it richer while on the spray? That's the way I have mine set up right now. I went a couple tenths richer on the tune just for safety.
