My first scan please comment.
Old Jun 3, 2006 | 12:32 AM
ls1_bc's Avatar
Default My first scan please comment.
This is my first scan. Would be great if you guys could comment or suggest what changes I should make. Car is pretty stock. LS1 motorsports intake,FastToys ram air,!AIR,!EGR that's about it for now.More to come soon when I learn how to master EFILive
Thanks
[IMG][/IMG]
[IMG][/IMG]
Old Jun 3, 2006 | 08:55 AM
Super Speed's Avatar
4 degree of knock retard! I can't really see the one above it though its too small
Old Jun 3, 2006 | 01:55 PM
joecar's Avatar
You're off to a good start, knowing what's going on is more than half of the story...
At WOT, your HO2S11/21 voltages are a little low at 860-880mV meaning it's lean, you want to observe these being something like 930-950mV (see next paragraph), this could be the reason for the knock you're seeing;
you can fix this using a WBO2 sensor to tune the VE table and MAF table and then setting the PE vs RPM table to get richer at WOT (and verifying using the WBO2S);
use the WBO2 to make changes; use the HO2S11/21 voltages for observation only.
Other ideas:
display MAF and MAP in metric (easier numbers, at least for me anyway);
in a log chart, display as many PID's as you can, more info = better analysis.
make your pictures a little bigger.
Old Jun 3, 2006 | 09:30 PM
ls1_bc's Avatar
I resized the pics....I hope this helps.
