Wide Band O2 In Stock @ SDPC
Old Jun 3, 2006 | 04:19 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Default Wide Band O2 In Stock @ SDPC
SDPC has a large supply of wide band parts from Innovate Motorsports and wanted to let everyone know what we have!
Tuning an engine for maximum power previously required long trial-and-error sessions on a dyno. With the LM-1, precise AFR measurment allows the user to correctly adjust many variables- including carborator jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sesions. Themeter's digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1's self-calibrating circuitry also compensates for changes in temp, altitude, and sensor condition.
LM-1 Basic kit
Includes an LM-1 air/fuel ratio meter, Bosch 5 wire wideband o2 sensor, analog output cable, 10ft sensor cable, 10ft power cable (cig), 6ft serial cable for pc connection, bung/plug kit, software cd, and quick start guide.
Part # INN3723.......LM-1 basic kit.........$349.95
LM-1 kit with Auxbox
LMA-3 includes all the above parts including a Auxbox LMA-3 input accessory.
INN3756..............LMA-3 with Auxbox.........$589.95
LM-1 kit with RPM converter
LMA-2 kit includes same as the LM-1, but also comes with an RPM converter
INN3724......LMA-2 kit with RPM converter.....$429.95
LM-1 window mount
the new "window mount" will allow you to have the LM-1 mounted to your windshield. This will help provide a better view of the display while tunning.
INN3751..............$75.95
Heat-Sink bung extender
The HBX-1 is intended to provide a degree of thermal isolations where the pipe temparature exceeds 900F (aprox. 500C) with a heat-sinking design intended to screw into a new or existing 18mm bung.
INN3729................$89.95
MTS carrying case
The MTS carrying case is a durable plastic case, designed to hold the LM-1 and all accessories included in any configuration of the MTS kits.
INN3754.............$55.95
Bosch oxygen sensorBosh LSU4.2 5-wire, wide -band 02 sensor
INN3737...........$79.95
AC power adapter
AC power wall adapter for the LM-1
INN3732...........$35.95
RPM converter for the LMA-2
The LMA-2 expands the LM-1 aux. input connector to 6 wire terminals (5 auxiliary inputes & 1 ground).
INN3726..................$99.95
Exhaust Clamp
Venturi-effect, tapped exhaust clamp for obtaining accurate lambda measurements in non-cat autos or other engines.
INN3728...............$75.95.
Analog display
52mm, 8-18 AFR needle gauge driven by LM-1 analog output. **Requires "Analog Output Cable" not included**
INN3731.................$59.95
Inductive pickup
Inductive pickup for use with RPM converter or the AuxBox, 6ft
INN3731....................$19.95
AuxBox for LMA-3
The AuxBox attaches to the auxiliary input of the LM-1 and allows a user to log and analyze 5 critical engine metrics in addition to the air/fuel ratio native on tuning kit, allowing the user to capture , view, and analyze data on all 6 channels.
INN3742......................$249.95
There are a few more items that we have on the shelf that I have not listed. Please feel free to call, pm, or email me with any questions
