Accel enrichment
Old Jun 4, 2006 | 08:34 PM
jub jub's Avatar
Default Accel enrichment
In EFILive, what table do you adjust for sudden enrichment upon acceleration? Is there an adjustment similar to what would be considered an accelerator pump or it does the PCM react fast enough, it's not needed?
Thanks for your time.
Old Jun 5, 2006 | 07:31 AM
jub jub's Avatar
Is this such a difficult question or am I asking the obvious?
I've looked at the PE tables and none of them seem to fit the description of what I'm looking for.
Old Jun 7, 2006 | 09:19 AM
RedWS6 00's Avatar
You could bring you PE down so about 25% throttle it state Power Enrichment. Think defauls is around 60% at low RPM's, lower percent at higher PRM's, think playing with the PE thresholds is what you need.
