WTF?! I threw 7 OBDII erroe codes!!!!!Help!
Old Jun 6, 2006 | 01:03 PM
SHINER's Avatar
Question WTF?! I threw 7 OBDII erroe codes!!!!!Help!
I picked these up using a Diablosport, and Im worried about the unknown fault one, MAF sensor, and Generator circuit one. If you have ANY sort of information it would be much appreciated! ANYTHING helps! Oh and I have SLP longtube headers with an ORY with simulators
Thanks Have a nice day
Travis
P1637-Generator L Terminal Circuit
P1626-Anti Theft
P1415- Air System
P0704-Clutch Swith Input malfunction
P0650-UNKNOWN FAULT--???????????????????????????
P0135-O2 sensor Heater bank1 sensor 1
P0102-MAF sensor low input
Old Jun 6, 2006 | 01:07 PM
Camaroz's Avatar
Wow.. Your car is PISSED Sorry I can't help.
Old Jun 6, 2006 | 01:25 PM
ZL1Killa's Avatar
when did you have the headers installed? did you knock the sensor on the drivers side of the block?
also have you checked all of your grounds?
Old Jun 6, 2006 | 01:54 PM
SHINER's Avatar
where are all of my grounds, i had the headers installed around 3-4 months ago.
Old Jun 6, 2006 | 01:58 PM
ZL1Killa's Avatar
if its been that long...idk what your problem is.
you would have known about it within a few days if it was the sensor
Old Jun 6, 2006 | 02:20 PM
SHINER's Avatar
i think my engine is ok, pulls strong doesnt really sound weird or anything...
Old Jun 6, 2006 | 03:02 PM
ZL1Killa's Avatar
when did it start throwing the codes
Old Jun 6, 2006 | 04:29 PM
3rdgenguy's Avatar
back in the day i had a few obdI cars (GM) just throw random codes . i use to check them by tapping the pcm and seeing if you got anymore ( the old GM tap test) but again that was obdI cars ... just my .02 ceants
Old Jun 6, 2006 | 09:20 PM
SHINER's Avatar
TTT, what causes an unkown fault?
Old Jun 6, 2006 | 10:16 PM
fast98's Avatar
a p0650 is a malfunction indicator lamp control circuit code. to be honest its hard to just say what the problem is, but being as i work on these cars, my best guess is either a low voltage problem, so check your battery and alternator and if those check good, put a pcm in it. when you replace the pcm make sure and check the connectors to it for corrosion. i would take it to a dealer though to be honest, if it is a pcm it gunna be under warrenty if your car is under 80k miles
Old Jun 6, 2006 | 10:39 PM
SHINER's Avatar
well im passed warranty, so the unknown fault is NOT a mechanical problem i have some electric parts cleaner spray i might just un do the connectors on the PCM, and so forth and spray em clean. Will any PCM from a 99 M6 work? Could I get a 02 M6 PCM....i dunno they had 28lb injectors, does that make a diff?
Old Jun 6, 2006 | 10:57 PM
Camaroz's Avatar
Load testing the battery and alternator are good suggestions. definetly try those before shelling out for a new PCM.
Old Jun 6, 2006 | 10:58 PM
SHINER's Avatar
how do i do that, ive never had to do those things.
Old Jun 6, 2006 | 11:08 PM
Camaroz's Avatar
Autozone does battery load testing, Not sure about Alternators.
Old Jun 6, 2006 | 11:14 PM
ZL1Killa's Avatar
yeh, the can load the alternator...gotta take it off tho
Old Jun 6, 2006 | 11:27 PM
SHINER's Avatar
dammit...well it holds a charge so i dont think its the alt.
