99+ ECM conversion
Old Jun 13, 2006 | 06:43 PM
bigturboz28's Avatar
Default 99+ ECM conversion
I am looking to build a forged 402, but want to upgrade to 99+ ECM so I can tune it with MAP (HpTuners???). How easy/hard is it to convert to 99+ ECM?
Old Jun 13, 2006 | 07:09 PM
HOLY ****, i just read about the 98 2bar support! SO HAPPY!
Can I run 3bar on HpTuners new system? Anyone try???
Old Jun 13, 2006 | 07:52 PM
Josh@KY-Turbo's Avatar
No 3 bar yet. 2 bar OS support only so far. Still keeps us limited to 14.7 lbs of boost.
Old Jun 14, 2006 | 08:48 PM
Default Feedback from HPTuners
Originally Posted by bigturboz28
Quote:
Originally Posted by Chris@HPTuners
I have a 98 LS1 running 10lbs. boost, and want to know if your new 2bar setup can also support 3 bar? If not do you offer a product to tune my 98 LS1 with 18lbs. boost?
we don't have a 3bar option for the 98. Although you can easily use the 2bar setup and tune right at the top end for 18psi. Anything between 15psi and 18psi would just use the 18psi fueling etc. which would be slightly rich but nothing too serious.
Chris...
Thank you for the reply,
Are you planning on a 3bar setup for the 98's?
If I buy the 2bar and you release a 3bar what is involved to upgrade?
P.S. Thanks so much for the 2bar on the 98's by the way.
we are not planning a 3bar for the 98's at this time.
__________________
HP Tuners LLC Owner and Forum Administrator
