codes 1626,1637
Old Jun 16, 2006 | 04:28 PM
little john's Avatar
Default codes 1626,1637
Getting codes 1626 and1637.Car will not turn over.Is there any way to bypass or check the BCM?
Old Jun 16, 2006 | 04:59 PM
2001NBMZ28's Avatar
1626 is a theft deterrent fuel shut off code, 1637 is gen L terminal circuit - so you might have a couple things going on. Have you checked your GAUGES fuse inside the car?
Old Jun 21, 2006 | 09:25 PM
Default codes
Turned out to be the wiring in the lock cylinder.
