LC1 LED blinking errors, weird one going on...
When heating up, it blinks once every second consistently until towards the end where it stays lite.
Towards the end, I get a sequence like this illustrated by the B's for each blink and numbers for duration between each blink:
B12B12B12B1B12B1BBBBBBBB
Numbers between the B's are just the timing sequence, so 1-2 is one second, then the 1 is a quick blink between.
So is this an error of 2? It only happens once at the end and stays lite each time I start or restart.
after warm up....
it goes into blinking followed by a pause...
slow blink is warm up...
then fast blinks followed by pause...
count the excact blinks..after the warm up and between big pauses
then see pic below...
how many blinks...represents the error #
looks like you have error 8
do a full sensor recalibration...
unplug the sensor from the lc1..power on... let it sit for 10 seconds or more...
turn off...
re connect sensor(in free air) and power on LC1...
it will take it about 2 minutes to do a full recalibration...
when the recalibration is thru..you will either be all good...or it will return to blinking 8 times...or however many times it is blinking....
if its stil doing the fast error blinking....then you need a new sensor
after warm up....
turn off...
The cal wire is routed to both the supplied push botton and led (in parallel), and from there grounded.
