Engine backfiring after nitrous backfire.
Old Jun 18, 2006 | 03:48 PM
00Z28SS's Avatar
Default Engine backfiring after nitrous backfire.
I recently had a nitrous backfire that blew a hole in my intake manifold. I swapped the LS6 intake with the stock LS1 intake and the engine runs fine. Recently I have noticed that the engine will backfire at WOT tip in and sometimes at low rpm's. I have HPTuners and a wideband and I was just wondering how I would go about getting started on finding this problem and fixing it with the software; and how I would determine if it is a fueling issue vs. a timing issue.
Thanks everyone
Old Jun 18, 2006 | 04:08 PM
redsscamaroboy's Avatar
I might be way off here,but did you check your plugs after the nitrous backfire?
You could of smoked 1or2 and that is your back fire (missfire) now.
Old Jun 18, 2006 | 04:39 PM
00Z28SS's Avatar
I checked a few of the plugs, and the ones I checked looked fine. That's probably a good idea though to check to rest of them. The only reason why I DO think that the plugs are fine is because the backfire and misfires are intermittent, if I had a smoked plug/s I imagine the frequency of the backfires and misfires would be greater. Thanks for the advice though, maybe I should check the rest of them.
Old Jun 18, 2006 | 05:19 PM
1BADAIR's Avatar
did you replace the MAF?
Old Jun 18, 2006 | 05:47 PM
xaon's Avatar
You should check all of your plugs and do a compression test on the cylinders. Also look inside the intake for an excessive amount of oil.
I had a big nitrous backfire that blew the back of the intake out... it ended up toasting one of the pistons (broke a ringland) albeit the car still ran good. It eventually started having really bad blowby.
Old Jun 18, 2006 | 06:59 PM
00Z28SS's Avatar
What cylinder did you have a problem with the ringland? I heard on LS1's the very last cylinder on the drivers side will always go first during leaning, or nitrous backfires and such.
Old Jun 18, 2006 | 07:42 PM
xaon's Avatar
#6 was my downed soldier.
I've seen a bunch of motors break from nitrous... never any real consistant #7 damage. I've seen #6 more than i've seen #7. I've also seen #8 quite a bit.
On a big backfire... it's usually going to takeout whatever piston has the intake valve open and exhaust valve closed at that time.
