Spark MAP, SD Tuning Question
If you remove the MAF then the Spark table would have no depth, you would expect it to run from one line as there is no g/cyl input. When logging you can see the spark advance changing depending on throttle position, therefore it must be using something to substiture the g/cyl, but what is it? is it using MAP?
