Throwing a Code
Old Jun 25, 2006 | 08:46 AM
1BadBlueSS's Avatar
Default Throwing a Code
I was Driving to work today and my first SES light came on . I threw on the handheld and a code P1416 showed up. I looked it up and said it had to do with the AIR. Would that be the AIR pump going bad? I erased the code to see if it comes back up. Thanx for and info.
Old Jun 25, 2006 | 09:05 AM
1BadBlueSS's Avatar
I did a little more looking around and found Secondary Air Injection (AIR) System Bank 2 (GM) What does that mean?
Old Jun 25, 2006 | 10:04 AM
Purrvert's Avatar
Air injection into exhaust manifold at startup, passenger side, runs for about three minutes but takes its good natured time throwing the code. Look for a small pipe coming from header going to a round black check valve, thump it or replace it. Usually under ten bucks. They tend to rust shut.
Old Jun 25, 2006 | 10:51 AM
2001NBMZ28's Avatar
Yep, passenger side air check valve is most likely clogged - been there, done that. GM PN 12565503 or local parts store.
