ignition breaking up?
Old Jun 27, 2006 | 12:26 PM
burlst/a's Avatar
Default ignition breaking up?
tps is ok as well as map sensor voltage.car falls off after 5k rpms sputters no ping just as though i lost 2 cylinders .possible coils? any one got some info that can help?
Old Jun 27, 2006 | 11:15 PM
Billf6531's Avatar
First, check your wires and plugs. Most problems are caused by simple things. If you confirm that wires and plugs are good, let us know. Also what are your mods? Does this occur at high rpm only? If you're running forced induction, it's possible that your dwell time is short and you're blowing the spark out.
