Hesitation
Old Jul 2, 2006 | 02:52 PM
98camaroLS1M6's Avatar
Default Hesitation
I had hesitation off idle to 1500rpms. After 1500, its fine. I tried replacing the MAF, but it didn't work. Just recently, i've been gettin an ses light- po121 (throttle position sensor). After i delete the code, the hesitation goes away for a little bit then goes back on in a little while, followed by the ses light a couple days later. What are the effects of a bad throttle position sensor? Is it safe to say that my hesitation problem can be solved by getting a new sensor? Any help would be appreciated.
Old Jul 3, 2006 | 10:14 AM
Anyone???
Old Jul 3, 2006 | 10:33 AM
stangbangin69's Avatar
a new tps only costs like $42. sounds like that is the problem to me... replace it and u should be fine...
Old Jul 3, 2006 | 01:10 PM
does getting a new throttle position sensor require tuning or no?
Old Jul 3, 2006 | 01:23 PM
ringram's Avatar
No, just make sure its reset to zero.
