Car wont run in SD. Dies without the MAF!
There are these 2 codes in there right now:
P1518 "Throttle Actuator Control (TAC) Module Serial Data Circuit"
P0108 "Manifold Absolute Pressure (MAP) Sensor Circuit High"
I dont know what it means but the MAP sensor seems to read fine on the logs.
What do you think its causing the car not to run in SD?
Thanks.
