Taking out PCM
Old Jul 5, 2006 | 03:33 PM
got V-8?'s Avatar
Default Taking out PCM
How do i Get my PCM out of my car? I'm running a feed line for my nitrous through there and need to get it out for a second
Old Jul 5, 2006 | 03:56 PM
12secSS's Avatar
You can remove the two 10mm bolts that hold the PCM bracket in place, or you can remove the two 7mm (IIRC) bolts that hold the PCM connectors to the PCM and slide the PCM up and out.
Old Jul 5, 2006 | 04:13 PM
2001NBMZ28's Avatar
If you remove the connectors disconnect the battery to be safe.
