Too Lean Bank one - bad injector?
Today, however, I got a code - Too lean Bank one. Bank one is DRIVERS side; right?
Is this likely a bad fuel injector? These are stock 99s.
1. was any exhaust work recently done? could be an exhaust leak at the head or the collector, this would suck in raw air and cause a false lean code. Tighten the header bolts up
2. Bad Injector -- do you have access to a heat gun? You can check the temps of each primary, if one is significantly lower then that could be the issue. A bad injector should eventually set a code, but I'm not sure how long it takes or what procedure it uses to determine an injector is bad (could be a clogged injector... in which case it is working properly but not enough flow)
If you don't have access to a heat gun, you could try swapping injectors... move all drivers side to passenger side and vice versa... see if the code follows
Is the Bank 1 the driver side?
I thought of switching Bank 1 and Bank 2injectors - good idea.
Thanks...
The rear O2s shouldn't have anything to do w/this code, the front O2s can sometimes have problems with Long Tube Headers where they throw an Insufficient switching code, but the long tubes themselves shouldn't cause a lean code unless there's a leak or bad injector
If there's an exhaust leak it should be audible (you could try using the screwdriver test... get a large screwdriver, put it on metal and put your ear on the end, lets you hear what's going on much better and makes it easier to hear an exhaust manifold leak)
The last time I replaced front O2s the cable on one side (passenger side I think) was too short. I spliced in an extension. Would this cause a "too lean" code? I'll have to check which side I spliced.
Plus if this problem just started, and it's been like that for a while... it's likely not that
So I'll try these:
1. Check electrical ground (Back of driver side head???)
2. Check exhaust header for leak at head or collector
3. Swap O2s left to right
4. Check intake manifold for leak
5. Swap injectors left to right
6. Check fuel rail pressure
Anything else?
I'd check passenger side O2 first, then check for a header leak on the DS. If you want to eliminate the bad O2 scenario, set your car in open loop and see if the problem persists.
I suppose if the leak was right at a intake manifold seal, such that it was only allowing excess air into 1 cylinder this would be the case
but it would have to be a large leak (since a too lean code is set when the PCM can no longer accuretly compensate fuel wise... this means that it's already tried adding 25% fuel to the 1 side and it's still running lean)
plus an intake manifold leak will usually cause the idle to fluctuate wildly since it's a vacuum leak
Recently made a few simple mods,
maf, throttle body, cat back, air box and K&N and hypertech tuner (for higher octane fuel),
just after these I got the code for both banks being lean, after advice I removed the TB and all has been ok for a couple of weeks. Today just the bank one code displayed after hard acceleration.
could it be:
oil from the new K&N fouling the maf?
too much air for the fuel going in? Though 25% more fuel by the PCM would surely cure this.
Does this info prompt any ideas to help us?
Im hopeful cos there arent too many people with LS1 experience her in London UK
