Air Pump Question
Old Jul 13, 2006 | 08:48 PM
shadss's Avatar
Default Air Pump Question
Lookin for any input on a problem I have been having/still having with a check engine light coming on. The code that comes up is po41o (secondary air injection). I recently had a new air pump put on thinking thats what the problem was. Roughly two days later the check engine came up again with the scan telling my guy its the same problem. He tried doin a lil research but didnt come up with much. So if any knowledgable guys out there could lead me to a solution, I would greatly appreciate it. Thanks alot guys.
Old Jul 14, 2006 | 09:32 AM
Grimes's Avatar
well, to tell you the truth, you could just get the codes deleted by someone with editing software. but since you just got a new pump, you could check to make sure it is plugged in correctly, that the relay is good, that the fuse is good, and that all the tubes are connected.
Old Jul 14, 2006 | 09:28 PM
shadss's Avatar
Thanks alot for the input. Any other suggestions out there?
