HPT Editor program error.
Heres the error info..
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: Error creating window handle.
at System.Windows.Forms.NativeWindow.CreateHandle(Cre ateParams cp)
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.OnVisibleChanged(Even tArgs e)
at System.Windows.Forms.ScrollableControl.OnVisibleCh anged(EventArgs e)
at System.Windows.Forms.Control.OnParentVisibleChange d(EventArgs e)
at System.Windows.Forms.Control.SetVisibleCore(Boolea n value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at u.?(ak A_0, ? A_1)
at u.?(ak A_0, String A_1, String A_2, String A_3)
at u.?()
at n.?(Object A_0, EventArgs A_1)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
VCM Editor
Assembly Version: 2.1.12.0
Win32 Version: 2.1.12.0
CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/VCM%20EDITOR.EXE
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
C1.Win.C1FlexGrid
Assembly Version: 2.5.20053.220
Win32 Version:
CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Win.C1FlexGrid.DLL
C1.Common
Assembly Version: 1.0.20031.116
Win32 Version:
CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Common.DLL
C1.Win.C1Chart
Assembly Version: 1.0.20053.15236
Win32 Version:
CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Win.C1Chart.DLL
C1.Win.C1Chart3D
Win32 Version:
CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Win.C1Chart3D.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
