Me no stumble now!
My car was acting up for the last few months - low on power and stumbling on acceleration. Finally, it throw a code last week PO171 - too lean Bank 1.
I tried everything to fix this issue including:
1. Plugs
2. New front O2s
3. Vacume leak test - manifold, MAF
4. PCV leaks
5. Exhaust leak - head and LT collector
...nothing seemed to cure the issues.
Finally, I pulled out the old factory MAF and replaced the SLP 85MM unit I bought about 4 years ago.
Bingo - the car is running great - no stumbling at all - MUCH more power too.
1. Plugs
2. New front O2s
4. PCV leaks
The SLP unit that was bad was "calibrated" by SLP. WHen I bought the thing they make you fill out a questionaire about the mods you have. The unit came with a resistor type device that is plugged into the cable between the MAF and the PCM.
Anyway, I tuned the car with Edit afterwards and it ran great for a few years. I'm assuming the MAF went south and that it does not have anything to do with the tune.
Is this correct?
Is this correct?
