Spark & Air Flow Question.
So in the case of WOT we advance the timing to increase air flow.
Now on Idle, I wanted to make the car use less fuel on Idle. The idea was if I create less air flow I can then put in less fuel. Of course there is a limit to how little air you can flow until it stalls.
My Idle spark was 21 degrees. My air flow was 0.80lb/min, I would assume you decrease the timing to create less air flow as it would e the oppersite to WOT, degreese all the way to 0 degrees eventually, the tone of the engine changed, didn't note the Air flow reading but noticed my injector duty cycle increased. So this was the wrong direction to go. I then went from 21 degrees up to 40 degrees spark advance, noticed my Air flow went from 0.80lm/min right down to 0.52lb/min. My IAC was down to 0. So this was too far to go. Have settled on 38 degrees for now, idles great, better than 8% fuel saving on idle.
So my question is, at WOT we increase timing to suck in more air. On idle we increase timing to suck in less air.
Why?
