can the iac be deleted or removed without causing a check engine light
Old Jul 21, 2006 | 10:30 AM
brandonppr's Avatar
Default can the iac be deleted or removed without causing a check engine light
I would like to not use the iac but don't want a check engine light is this possible?
Old Jul 21, 2006 | 11:17 AM
2000TransAmWS6's Avatar
not trying to flame you or anything, but why would you want to remove it? its not causing you any harm is it?
Old Jul 21, 2006 | 04:00 PM
brandonppr's Avatar
1998 z28 auto. first off all I use this car for is bracket racing on 1/8th mile dragstrip. for some reason when I stage the car and the iac is plugged in my rpm fluctuates a little but if I unplug it it holds steady. also it idles better with it unplugged. I am sure that the idle problem could be tuned out though. it has a ms3 cam, heads, and most normal bolt ons, forged rods and pistons. 3500 stall.
I was looking on the net and found this http://modernmusclecars.net/forums/articles.php?do=emic from what I understand is that the check engine light won't come on unless the idle is 200 above or below what the computer thinks it should be at idle. right now I just have it unplugged and it took a few tries to unplug it at the right time so that the idle is where I want it. is there a way to make the computer not care about were its idling. its not that big of a deal but I would like the check engine light off so that I will know when something is not working such as o2 sensors etc.
