HUGE gains with MAF removed completely...
I definately believe the stock 75mm f-body MAF is a big restriction on a modded car, which is why im such a big fan of ported MAFs, assuming theyre recalibrated afterwards. I do find it a little difficult to believe that an 85mm de-screened maf would restrict you to the tune of 20 rwtq though.
i'm sticking to this.
He was already in speed-density mode. The tune did not change and was not altered. The MAF was not functional, it was only along for the ride... Any gains would have come from removing a physical restriction.
I do agree with you that there should be no difference between properly tuned MAF and SD setups, all else being equal, ie. unplugging the MAF but not removing it.
maybe i referred to the wrong person in my first post... or something IDK,...
but this thread is what I was talking about, HumpinSS tested this.
For all intents and purposes, its as if the MAF has already been unplugged, but he realized the gain when he physically removed the MAF, even though it had been unplugged and rendered inoperable for some time.
Do I think this guy's results were extreme? Yep, sure do. I'd even feel confident saying something (unknown) impacted the dyno result. Maybe the shop prankster was squeezing off a little nitrous in the cooling fan during the run, I dunno. But he made one change in a tight enough time span that the weather didn't likely change, and made a big power increase.
I'd personally like to see the same thing done another time or two on the same dyno just to verify or disprove that the MAF in the intake path was what was holding it back.
I am not saying that in this case there is not a power increase. I'm saying the MAF housing itself (the area of the section plane) if unrestricted, offers no sizeable benefit when removed. The title of this thread is a bit misleading in that it will have unexperienced tuners rushing to remove their MAFs and once again there will be a useless debate about which is better b/w MAF and SD. The numbers compared here are merely estimations the PCM outputs in order to reference saver functions, certainly not to be held for any real word comparison. I am not the only one to verify these concepts, just trying to keep us all on earth.
I think we're all in agreement here.
Obviously the guy's MAF was a restriction.
