a4 computer with turbo 400 transmission
All you need is the speedo hooked up. Beyond that the computer will not control anything else in the trans, but it may need a speed input that the th400 can provide. What problems are you having?
Originally Posted by black98ws6ta
Without the computer being modified, doesnt it still see the car is in park? So timing and fueling would be off to go WOT?
Also Im guessing on a turbo car, with it on the brake the car uses the "in park" timing table, then as soon as it moves and sees mph it references the high and low octane tables. I may need to change the timing table for when I am on the brake,k does all of this sound right?
No, it also uses TPS to change which table it will reference. I have Jen's race car setup to activate the Primary Spark table at 2% TPS, and when logged you will see it does select a different table (if the values are not identical on both table ... then it would matter). So to activate the main spark tables you only really need TPS input, not really the speedo. We have no speedo in our race car and as I said, it references both Idle and Maim spark table as I have defined.
Where do I change which tabes it uses(like you did with 2% tps)? If I could get it to idle in the park table, then go to the high/low spark advance tables I would be fine. I was going by what was posted earlier on the computer using mph to change from tables.
