Firming up shifts?
The best way is to change the "shift time" tables rather than editing any of the line pressure tables directly. Lower the shift times in those tables for firmer shifts. Don't set any below about 0.15-0.2 sec though as the trans doesn't usually like anything lower than that.
You might also want to increase the max line pressure constant. I think I set mine to 110 or somewhere around there.
