Ignition problems
Old Aug 3, 2006 | 04:41 PM
81LS1Camaro's Avatar
Default Ignition problems
I have had problems with my car surging at low speeds about a week back but the problem seemed to go away. Then yesterday I was driving and it started surging, backfired, surged some more, back fired and died. I was able to get it restarted after a bit of trying and barely made it home. It was running really rich and missing real bad.
I pulled codes and got
P0352
P0353
354
355
356
358
I know that these are coil control circuit codes, and was just looking for some advice on what to start looking at. Am I right in thinking about looking at all my connections and checking for broken wires?
Let me know what u guys think.
Old Aug 4, 2006 | 02:37 PM
Z28_DAD's Avatar
check the connectors. if they are ok, then pull the plug wire off the coils and start it, if you can see the spark arcing, the coils are good.
Old Aug 5, 2006 | 12:56 PM
I figured out my problem last night. It only took about 5 minutes to find. For some reason the bolt with the 3 ground wires from the harness was loose.
