knock question
Old Aug 11, 2006 | 05:56 PM
stokishZ's Avatar
Default knock question
is there any way to adjust the sensitivity of the knock sensor (using efi live) ? the reason i ask is because my headers are hitting the floor board and i think that i would have to bend and beat to much to fix the problem that way, so i was just wandering if it was possible?
Old Aug 12, 2006 | 09:47 PM
dissonance's Avatar
To rid yourself of timing retard via knock then you will need to almost completely disable the knock sensors. This could cause some major problem. I would still fix the header problem as soon as you can. I’m sure you already know this, so I will just get to the point.
Edit B6245, higher the number the less sensitivite the pcm will be to the knock sensors, stock will show 1.0 in “inHg 19.2 – 29.5” just increase these numbers until the pcm does not retard the timing. step value up 1 point at a time until the knock is gone.
There are other ways to disable the sensors but this will have the same affect.
Old Aug 13, 2006 | 01:51 PM
stokishZ's Avatar
preciate the help!!
