done with SD, plugged maf in...
Nino
If so adjust your maf table based on AFR % error from commanded AFR.
Ie if it runs 10% lean over the whole table, scale your maf table up 10%
You might need to take a look at tuning idle by logging running airflow and desired airflow . Do a search for tuning RAF on hpt or efi depending on what you have.
