Engine Sens Fuse C5
Old Aug 16, 2006 | 08:14 PM
dirty2kTA's Avatar
Default Engine Sens Fuse C5
Does anyone know where the engine sens fuse is on a c5. I have checked underneath the hood and under the passenger floor board. My car is throwing the p0101 code. I have replace the MAF, MAP, and I have reinstalled the intake to check for leaks...MTI and other people are telling me to check the eng sens fuse. What is it actually labeled????
Thanks
Old Aug 16, 2006 | 08:37 PM
2xLS1's Avatar
Are you sure it is not in the under hood fuse box? That is where it is on f-bodies and is labeled Eng Sens. It sources 12V to the MAF and all 4 O2 sensors.
Old Aug 16, 2006 | 09:51 PM
dirty2kTA's Avatar
Default eng sens
I have looked underneath the hood but did not find a sensor with that name. I saw a PCM/IGN. I checked all the fuse that I thought it could be. I have a 99 camaor and I located it on the car. There are other F-bodys on here that are having the same problem code p0101. It throws many codes, like they are all on the engine sens fuse.. I am lost.
Thanks
